TVP 10 pro shuts down without warning.
Henk Beumers
Re: TVP 10 pro shuts down without warning.
Post by Henk Beumers »
Hi again.
Again a crash this morning although I ran the last update yesterday.
Henk.
Henk Beumers
TVP 10.05.7 pro 64 bits W7 pro 64 bits. Intel i5 2.67. Mem 16gig.
Mads Juul
Post by Mads Juul »
Henk Beumers wrote:Hi again.
ene
Henk.
Just a wild guess. Do you have Subpixel enabled in the Preferences>General Tab?
If not then try to enable it. If I don't enabled it my zoom is behaving strange maýbe it has something to do with this.
Else what tool do you have enabled when using alt+rmb. what timeline is you in project or clip is these . Try to take note of these things if you will try to find a pattern in a crash bug. In my experience a crash never occurs random there is always a system. because a computer is not doing anything random. But it can take a long time to figure out the pattern that trickers the crash.
-Mads
Henk, can you try to :
* start the software by holding the ctrl key.
* delete your configuration. (be carreful you will loose your brushes, papers, shortcuts, etc ...)
see if it's still crashing.
Henk Beumers
Hi again.
Update didn't solve the problem. This morning crashed again.
Henk.
Henk Beumers
did you try the reset of the configuration ?
Henk Beumers
Hi Fabrice.
No, I posted the answer before your reply.
I just started TVP while holding the CTR key. Yet all my settings are the same. I must have done something wrong?
Henk.
Henk Beumers
When holding CTRL while starting TVPaint, do you have a window that appears ? That window proposes you several thing, notably to create a new interface.
Did you have that choice ?
Secondly, did you recently update your Wacom drivers ?
Henk Beumers
Hi Elodie.
No I didn't got a window with options. It just started up like normal. I did not updated the drivers of my wacom tablet recently. I use a old USB model Intuos and it seems as if there are no updates available anymore. If I try to update I get the message the drivers are oké. Could it be old age of my wacom? I hate to dispose of things that work very well.
But I didn't had a crash this day, so who knows. In the mean time I have to finish a job in the next week, so I save every time I think of it.
Henk.
Henk Beumers
that's the rule of thumb for sailing: the first time you think of shortening your sails before a storm is the right time to do it. Once the storm hits it is too late. Same with the save button. :)
Henk Beumers wrote: No I didn't got a window with options. It just started up like normal..
Okay, so let's do it differently.
Go to Edit > Prefrences > Startup tab and choose "Startup panel".
Close TVPaint Animation and start it again. Then, you will obtain the wished windows =)
startup panel.png (61.82 KiB) Viewed 20304 times
Henk Beumers
He all.
Been out in the Studio prepairing stop motion shoot. Will be busy for the whole week. I'll have to see how things go. I keep you posted.
Thanks Henk.
Henk Beumers
Allow me to remind you about some less obvious possible causes:
- does TVP behave the same (= crash) when you put the dongle into a different USB slot?
- do all other applications behave correctly?
- do you use external drives? Or drives over a network?
hmmm, so far it never happened.
We already had problems of dongle recognition and then the well known popup (dongle not found ....) but not any crash because of that.
but ok, you can try an other USB port. Who knows ? :?
Sandra thought at one point that her strange crashes while exporting TVP files might be caused by her external HD that she has installed to make automatic backups of everything on her computer, but turning it off changed nothing.
Paul Fierlinger wrote:Sandra thought at one point that her strange crashes while exporting TVP files might be caused by her external HD that she has installed to make automatic backups of everything on her computer, but turning it off changed nothing.
I think Sandra has an other problem. (Henk has random crashes at any moment when using TVPaint)
nb : check also the Wacom drivers, don't be afraid to reinstall them even if you are up-to-date.
