TVP v10 freezes when 'grab tool'
Re: TVP v10 freezes when 'grab tool'
Are you using the default right click on your pen, the one that comes with the bottom rocker switch, or do you use one of the keystroke options? I've always wondered if it makes a difference.
BenEcosse
Post by BenEcosse »
I have to tap and move the point as well as clicking this button to get the 'right click' function to work.
Astonishing! I've never come across this before, unless by "tap" you mean press, which would be normal. But you say, In TVPaint I have to tap and move the point as well as clicking this button to get the 'right click' function to work, and that I have never seen. Which tablet?
BenEcosse
Post by BenEcosse »
wacom intuos 3
It really shouldn't be this way. Without subpixel enabled you are going to get bitten somewhere down the line, there has to come a point where your line will suffer for this. I wonder if this might have something to do with your mouse settings in the PC OS... but I'm just grasping for straws here... at least that's where I would start messing around if I were in your place. :|
BenEcosse
Post by BenEcosse »
ok
lemec
Post by lemec »
Ah. Check your Wacom tablet's control panel and make sure that "hover click" is enabled (not click+tap) in the advanced settings.
(Win7x64, TVP Pro 11 32-bit)
Brilliant! (I think...)
BenEcosse
Post by BenEcosse »
'hover click' is already enabled.
lemec
Post by lemec »
Are you able to right-click (with wacom tablets) on your system at all? (also, PC or mac) and does the problem persist when you perform the same actions with the mouse?
I'm trying to make sure that this is a tablet issue.
BenEcosse
Post by BenEcosse »
Yes, I can right click (while hovering)
lemec
Post by lemec »
Ok, sorry I couldn't find something conclusive. Well, let us know if you run into anything else.
