Free Transform Selection Tool?
TVPaint
Post by TVPaint »
yes it's true that it just slow the flow if you always have to place the freshly cut part of your drawing and I bet that it will be fixed soon.
D.T. Nethery wrote:...
I still wonder why the keyboard shortcuts Z and C using the Magic Wand tool make the image shift over to the left instead of staying in the original position ? This seems like something that could be fixed in the next release of TVPaint.
the reason has to do with an interface problem
it jumps because your penpoint remains at the same position but the function of the penpoint changes.
as a brush the penpoint holds the brush pivot
but in rotation mode the penpoint holds the rotation handle
and in size mode it holds the scalecorner.
its a tricky problem
i you want a penmovement to control rotating and sizing what happens with the pivot point? something has to move!
so Nicolas... i'm curious if you can explain what your betting for exactly :D
