Brush Rotation and Modify Handle
Re: Brush Rotation and Modify Handle
notice that tvpa v9.0.2 is required for the free-Resize tool.
btw, there's still a little bug with this tool :
when you rotate the brush in first, then doing a Resize (the old one, with keep ratio),
you can click & drag the corner of the box to change the size, the brush being displayed
with the right angle of rotation,
now, try to do the same, (Rotate the brush, then Resize) but with the new free-Resize tool,
you have to resize the brush in the HUD without the Rotation, (like a "Rotation Reset" on the temporary display),
then, once resized, the previous rotation is performed again, with the new (free) size.
So, the result isn't wrong, but the HUD preview is somehow "counter-flow", and propicious for brain fever... :)
elmisilhumano
Post by elmisilhumano »
Is there a way to make buttons to set smooth mode to medium or best? The old B.E.T always set the subpixel on if I remember correctly.
M.
Mikko Vormala
just add a command line to the button (I'd insert it as the first line):
tv_BrushRestore Subpixel 1
or
tv_BrushRestore Subpixel 2
1 = medium
2 = best
0 = none
elmisilhumano
Thanks a lot Sven! My life is better now.
M.
Mikko Vormala
Sewie
Post by Sewie »
Mine too ! Thanks alot for that last tip, Svengali !
