Only show instance 'squares' when usefull.
Re: Only show instance 'squares' when usefull.
Well, your rooms can be configureds differently, with different panels, colors, etc...
That's the purpose of the room. :D
Lukas
Post by Lukas »
Elodie wrote:Well, your rooms can be configureds differently, with different panels, colors, etc...
But does it store all 4 rooms in the same configuration (the configuration folder on the hard disk), or can you have 4 different configuration folders? (I mean the path you can edit in the startup window)
  • LukasKrepel.nl
  • TVPaint Pro 11.7.5
  • YouTube.com/@ClubBaboo
  • YouTube.com/@FrameOrder
Then aren't you asking if you can open two or more TVP projects at the same time, which is yes. The advantage of the rooms as I see it, is that you can work on the same project in 4 different rooms of the house, each one specialized for different tasks.
Lukas
Post by Lukas »
No I'd want to be able to access multiple configurations in 1 tvpaint project. Not multiple projects or anything. I'll try to explain a bit clearer.
I have all my TVPaint settings in a dropbox folder.
"/Volumes/Dataatje/Dropbox/TVPaint/Lukas/tvp animation 10 pro/"
That way, I can always access TVPaint where-ever I am, if I need to work on a laptop, I can just install dropbox and set it as my configuration folder and am good to go (of course, I will forget my dongle is at the studio, so I'll probably be screwed anyway).
But right now, I'm working on a project with Joost and it would be nice if he could simply hop on my computer and change a drawing or something. He has saved his configuration in the same dropbox folder. So even if he is working on his own computer and changes his settings, they would also be changed on my hard disk. So there are two configurations on my HD:
"/Volumes/Dataatje/Dropbox/TVPaint/Joost/tvp animation 10 pro/"
Now it would be nice to set up the rooms so Room 1 would use the shortcuts and panels from the first path, and Room 2 would load them from the second path. So if Joost changes a shortcut on his computer last week, I don't have to worry about importing his configuration manually. And we could easily work on eachothers systems without being confused about shortcuts etc.
  • LukasKrepel.nl
This is so anathema to the way I work that my head spins just trying to imagine what life would be like for me under such collaboration efforts (LOL). This is certainly not a subject for me to get into but at least I made a contribution by getting your wishes better expressed and I'm sure someone will get back to you after the weekend...
For a discussion of this very subject (customizing and installing infinite rooms) and a solution you can explicitly use in your case you can look at the following (read to the end of the thread):
"Customizing and hot-swapping room data"
You'll probably have to experiment a little bit - be sure to backup your critical room data and use test data until you understand how magic numbers work.
Maybe starting a separate new subject/discussion-thread "Customizing, Saving and Restoring Room Descriptions", a title that makes more sense than "Freezing Rooms" or "Only show instance 'squares' when usefull" would be helpful for anyone else in the future searching for info, about customizing and randomly loading room descriptions?
Share what you learn as you solve your problem - would be the sporting thing to do. 8)
p.s. Thanks Zig and Masterchief...
Lukas
Post by Lukas »
Thanks! I'll check it out :)
  • LukasKrepel.nl
