Standard layer attenuation percentage
Re: Standard layer attenuation percentage
Well yes, I am in agreement. I just have reservations about this thought:
so maybe change the default value to 30% or something?
which suggests we have a standardized average, which would be impossible to ascertain, wouldn't it? Therefore lets have each user define their own preferences by having the last setting be carried over to the next project. If 30% would be the default it would be for me the same as zero because my values are usually under 20% -- sometimes way below 20. That's all I meant to say (and had said :) )
Elodie wrote:So, if you focus on all other parameters from the panel "Display settings", TVPaint ALREADY remembers the different values each time you create a new project. So, for me, the layer attenuation should behave exactly like the other parameters from Display settings. You set the percentage of your choice, and it remains the same, whatever your project is, until your decide yourself to change it.
I haven't figured out how to make Stencil options under "Display Settings" persistent either... is that a bug too or am I just not understanding how to do that?
I haven't any problem with that Svengali. The Stencil options stay the same (I mean, if I have changed them, I always have the same changes, they are not reseted), whatever if I open or create new project
Elodie wrote:I haven't any problem with that Svengali. The Stencil options stay the same (I mean, if I have changed them, I always have the same changes, they are not reseted), whatever if I open or create new project
Updating my question from a while back...
Actually I was asking if it might not be possible to have the setting for Stencil opacity be persistent (remain at its previous setting) from SESSION TO SESSION (each time TVPaint is restarted at the same setting as when I last exited)?
IF not, I'd happily include a George command to set the stencil's opacity in any button that manages various stencil operations.
In a similar fashion, I've been trying to use tv_Display "LayerAttentuation" Toggle 45 to toggle the other layers' attenuation, set to 45% transparency... but I can't get that to work either.
In fact, it might be useful to have an entire set of tv_Display commands that could set up all of the Display Settings options: for Check box, RGB color and transparency as part of any George script.
Lukas
Post by Lukas »
What if we could set default Layer Attenuation in the template file for new projects?
I rarely use the function because it always resets to 0% (and it takes a lot of clicks to change it), which is a shame, because it's very very useful. :)
99% of the TVP files I have have the setting at 0%, so the shortcut to turn it on is useless.
George acces to get/set all display settings would be great too.
  • LukasKrepel.nl
  • TVPaint Pro 11.7.5
  • YouTube.com/@ClubBaboo
  • YouTube.com/@FrameOrder
Ok, interesting request. I to do list it (both for george command and for "remembering" it)
Mads Juul
Post by Mads Juul »
Elodie wrote:Ok, interesting request. I to do list it (both for george command and for "remembering" it)
I think there is a George Command. It was not put in the WIKI yet
So I have just put it in
http://wiki.tvpaint.fr/index.php?title=Tv_Display
You can both get and Set the Layer Attenuation
-Mads
Thanks.
Ok, nevermind ^^
Lukas
Post by Lukas »
-Mads
Thanks!!
  • LukasKrepel.nl
Mads Juul
Post by Mads Juul »
I still think it could be nice for non George Scripters To be able to set the layer attenuation for all clips in an easy way.
Could you then make a suggestion ?
Mads Juul
Post by Mads Juul »
Elodie wrote:Could you then make a suggestion ?
Make a George Script put it in the Animator Panel maybe ?
Three way toggle button for attenuation...
LAYERS 3-way toggle.jpg (5.04 KiB) Viewed 29123 times
LAYERS 3-way toggle.tvpx
(82 KiB) Downloaded 1243 times
Thank you guys for the idea :)
