On my system, the file was in windows/system32/TVP_Thumbnail.dll
(With underscore)
Goto start menu > run >
type regsvr32 TVP_Thumbnail.dll
And that should do it for you.
Worked for me..!
C
thumbnails in windows explorer
- CartoonMonkey
- malcooning
You should unregister the dll file if you have manually registered it. Else the registry won't be correctly clean if you want to uninstall the software.
Since the 8.5 version of TVP Animation, the installer has been fixed in order to be sure to install and register the dll file. So to have thumbnails re-installed (or repair) TVP Animation 8.5. By using this way the dll file will be deleted and the registry cleaned when uninstalling the software.
Ex TVPaint Team
