file naming conventions for export
Re: file naming conventions for export
schwarzgrau wrote:I really like the idea. So if you got a long sequence you could export the whole sequence as png sequence and if you want to make corrections, you could only re-export the parts, where you made your corrections and it would match the already rendered sequence.
That's already how it works... Example, if you want to export a few frames from your project (for example 22 to 28):
1. Select Export to...
2. Select the path and a file name such as "myimages0022.png"
3. Select Mark In = 22 Mark Out = 28
4. Click Export
hehe ok thank you
