3 point spline artefacts
furushil
Re: 3 point spline artefacts
Post by furushil »
Elodie wrote:Is the bug happening on both computers ?
Yes, it is happening on both computers. I tried it on a third different computer now (Windows7, TVP 10.5.7 Standard, wacom bamboo fun) and the same bug happens.
Edit: maybe this gif helps to solve the mystery
Mads Juul
Post by Mads Juul »
I can repoduce the Artefact
1) create Default Configuration when Opening TVP
2) Select 3 pts Spline
3) Select Airbrush
4) Set Size to Pressure the artefacts will not appear is is none
5) set Size tp 10
6) Set Power to 100%
7) Draw some line
= Artefacts
Neither Fabrice nor I succeeded to reproduce the bug. Anyway, Jordane did !
Bug tracked.
Animark
Post by Animark »
Elodie wrote:Svengali, Furushil and Animark : what is your processor ?
Hope, it helps. My PCs processor is an "AMD Phenom II X4 955".
(I don't like it, because it is getting to hot. Next time I would prefer an Intel.)
TVPaint 10.5.7 - Win10/64
TVPaint 11.0.8 - Win10/64
Ok, Thank you : we thought it was related to processors, but it's not, as the bug happens on Intel and AMD computers.
Anyway, Jordane succeeded to reproduce it. At the moment, just disable the pressure on the size, until we fix that :)
furushil
Post by furushil »
If this bug is still relevant.
I found out that if you uncheck "Step", the bug will not appear (size still set to pressure).
Maybe someone else already noticed it.
furushil wrote:If this bug is still relevant.
It is still relevant.
Thanks for the informations added :)
