Annoying circle while drawing Topic is solved
Re: Annoying circle while drawing
good thing its solved.
I thought the cause might be found in your default brush and its setting.
are you still using the same custom brush?
just for testing i made a ridiculously large custombrush: 800x800 and 255 frames, set to Best smoothing
and behold... the blue circle appeared...
but, alas ... not in the same way as it did in your case, when i tried this tvpaint became so extremely slow it froze and when clicking elsewhere in the interface i saw the circle.
marijaye wrote:Hi Fabrice! With Wintab on or off, it still appears (real-time video attached).
And thank you again, Sven, I made that adjustment (and many others) yesterday and I believe they worked for programs like Photoshop, but TVPaint refuses to let go of that circle!
So I'm pretty sure it's not related to Wacom drivers.
It's something else in Windows 7.
marijaye
Post by marijaye »
Four years later, it strikes again! :( unfortunately my solution last time apparently was an accident, so I am open to any ideas about why every single brush stroke I make is followed by a little blue circle. I am on a Dell XPS 8500, Intel Core i7-3770, 16GB RAM, 64-bit operating system, x64-based processor, Windows 10 Pro.
Video attached.
This ONLY happens in the drawing area of TVPAint, not in any other program and not even in other areas of TVP's interface.
Any advice would be much appreciated! I have done everything already listed in this post.
20190830_191925.mp4
This was recorded on Augist 30, 2019...over 4 years from my original post!
(6.52 MiB) Downloaded 1287 times
mari jaye
Windows 11
11th Gen Intel(R) Core(TM) i9-11900 @ 2.50GHz
32 GB Memory
1TB HDD/ 1 TB SSD/ 2 TB HDD
Touch
TVPaint Pro 11.7.3 64-bits
cgmodeler
Post by cgmodeler »
Did you tried disabling Windows Ink
You can find it on Callibrate/Windows Ink checkbox at the tablet preferences panel.
That does the job for me.
www.cocoalopez.com
Soom
Post by Soom »
if that doesn't work, you might try disabling the Subpixel setting inside TVP Preferences
marijaye
Post by marijaye »
Sorry for the late reply...I got myself blocked from the forum when I updated some info.
I feel both ridiculous and also elated, and here's why! A few years ago, this problem popped up, and when it appeared again I was truly frustrated as no real settings had changed in that time. But now I know what was happening!!
I had printed some frames last time TVPaint was open, and so the print window was open when I started a new project. Every time I drew a line, the image in the print window updated...hence the "processing" circle. As soon as I turned off the Print window, the blue circles stopped as well.
Thank you all for your input! :D
mari jaye
Windows 11
32 GB Memory
Touch
Soom
Post by Soom »
marijaye wrote: 04 Sep 2019, 15:19 Sorry for the late reply...I got myself blocked from the forum when I updated some info.
Oh wow! Good to know! :/
BrownBear
Post by BrownBear »
Hello
I ran into the same issues with the spinning blue circle, everytime i was lifting my pen from my cintiq, after I made a line or erased.
I think i found a specific situation where this happens.
when I have a:
- anim layer and a color and texture layer underneath.
if I turn the icon "apply changes" on. on the color texture layer.
and draw something on the anim layer. the problem appears
and if i turn it off. problem seems to be solved
Hope this info can help others that runs into this kind of visual madness:)
- Also another idea: make a costum mouse cursor icon for when the mouse is busy.
an Icon that is nearly invisible like a dot. can also kind of fix the issue
I dont know if it can be fixed in TVpaint or not....hopefully:)
Best wishes
BrownBear
