I agree what changing Seed to Random or Random Jitter or something like that would make the function more obvious.Sewie wrote:But then why is this setting not just a button called 'random' ?? That would make things a hell of a lot more clear.Peter Wassink wrote:as i understand it, seed is like a dice role for the random generator.
so when you keep the seed number the same, the output of the random generator will also be exactly the same.
(that is... at least within one tvpaint session, because i don't know what happens when you restart tvpaint, this might also reset the seed randomness, i'd have to test it...)
only when you change the seed value, you get a new random output. "the dice are recast" you could say.
Camera moves
Re: Camera moves
Re: Camera moves
its a programmers thing: http://www.wikiwand.com/en/Random_seed" onclick="window.open(this.href);return false;Sewie wrote:...
But then why is this setting not just a button called 'random'?? That would make things a hell of a lot more clear.
be glad you can always learn something new
"random seed" would probably indeed be a better name.
