El Capitan
ten_zero
Re: El Capitan
Post by ten_zero »
Apple still has - or does not care - a problem on "Finder" "Preview" and "Quick Look" Adobe Photoshop 2bit B/W format analysis error from Mavericks (10.9.x) to El Capitan (10.11.x).
It's a seriously things for publish body text, novels or Manga (required CMYK 600 or 1200 dpi) PSD or ISO PDF/X-1a data.
However TVPaint Animation need not worry about that ; under using RGB only.
jorgepozo
Re: El Capitan
Post by jorgepozo »
Hi.
No other problems with "El Capitan" besides this crash "on quit" when full screen is activated. When the fullscreen mode is not active then you cannot draw properly (slow response from the tablet: jagged/polygonal lines).
If you forget to exit fullscreen you lose all changes in the panels,...
Not a very big deal, but is there an easy fix?
thanks,
Jorge
TVPaint 11.0.1 64
Re: El Capitan
jorgepozo wrote:Hi.
thanks,
Jorge
TVPaint 11.0.1 64
Current TVPaint version is 11.0.2.
As said in this topic : http://forum.tvpaint.com/viewtopic.php? ... ead#p88603" onclick="window.open(this.href);return false;
It will be fixed in 11.0.3
ten_zero
Re: El Capitan
Post by ten_zero »
Wacom released Tablet Driver V6.3.15-3 for Macintosh in 28th Dec 2015 (Japan Standare Time 9:00 A. M.).
 http://tablet.wacom.co.jp/download/down ... ?drv_c=593 (written in Japanese, multilanguage installer)
・Fix stylos pen stroke lo o o o oooooooo o o o ng delay (spot & delay considerbly) problem on El Capitan.
