50% TRANSPARENT for ALL LAYERS IN ALLCLIPS
Animationriver
Re: 50% TRANSPARENT for ALL LAYERS IN ALLCLIPS
Post by Animationriver »
Big THANK FOR YOU! :idea: :D
Hironori Takagi
Post by Hironori Takagi »
I rewrote a part of the ImportFolder script and tried to make it a panel.
Please check it.
ImportFiles_200122.tvpx
(75 KiB) Downloaded 1701 times
Animationriver
Hironori Takagi wrote: 22 Jan 2020, 06:18 I rewrote a part of the ImportFolder script and tried to make it a panel.
Please check it.
I am the happiest person! Thank you, HIRONORI! :D
Now I have a lot of time for effective work and life! :!:
Animationriver
Please check it.
Hello. I often take a while to download the files. And as they come from colleagues. I break them down into clips. And in each clip, I need to make the picture black and white. But when there are 100 clips, then I have to constantly press FХ STASK / color /color Adjust/ Saturation / -100 Saturation
Question.
You can give me a script. So that I can make all the pictures in all the SELECTED clips in the project BLACK WHITE with one button.
Help me please.
Hironori Takagi
I'm sorry.
I probably know how to make it,
But, I don't have time to support for free now.
viewtopic.php?f=10&t=14126
I also saw the above.
Are there any issues that haven't been resolved yet?
Animationriver
Hironori Takagi wrote: 09 Mar 2021, 03:53 I'm sorry.
I will collect problems with time. I will turn to you. When there will be critical questions. I am grateful to you for your responsiveness.
Animationriver
Hello.
I am very glad if you are reading this message.
I am having problems with these buttons. YOU made them great.
But after updating to program version 11.5.2, they do not work. I press .. but there is no effect. Could you help? Make them workers again?
y.tvpx
(291.5 KiB) Downloaded 956 times
Animationriver
Animationriver wrote: 17 Jul 2021, 14:11
Hello.
I reloaded the scripts and everything works again. That happens. Stops working. I do not know why.
Hironori Takagi
I tried only the "ImportFiles_200122.grg" button relinked.
You may try "ImportFiles" on attached file "test.tvpx" it works,
and if it works, the following causes are possible.
-There is a cause (Russian etc.) to break the link in the file path where you specified grg in "Set script" for each panel.
Please re-paste the link with the file path (C:test/xxx.grg) containing only numbers and letters. It may be resolved.
test.tvpx
(312 KiB) Downloaded 824 times
Animationriver
Hironori Takagi wrote: 19 Jul 2021, 12:10 I tried only the "ImportFiles_200122.grg" button relinked.
I run the test file. This is the Assembled button. But after clicking, the program crashes. Did it several times. I don't think it's worth thinking about this problem. Thank you for getting back to communication.
I reloaded the scripts and everything worked again. Thank you! :D
Hironori Takagi
I also read other topics you posted.
I thought: There seems to be another problem with the script that the custom panel doesn't work or crashes when used.
Animationriver
Hironori Takagi wrote: 27 Jul 2021, 10:20 I also read other topics you posted.
Hello.
I've always had it. I just wrote about it because the problem with saving the panel started to create negative emotions. The panels are very important. And how much I am sure of their safety affects the speed of my work.
Thanks. :D
