greatFabrice wrote:we need a complete rewrite of that code, it's on the TODO list.
Share your Interface Look!
Re: Share your Interface Look!
- Lukas Sketch Panel
- TVPaint Pro 11.7.3
- MacBook Pro 2018 macOS Ventura 13.4.1 + PC Windows 10
- Wacom Cintiq 27QHD + Wacom Intuos4
- YouTube.com/@ClubBaboo
- YouTube.com/@FrameOrder
I didn't say we will do it now. But yes, we are all aware of this weakness in TVPaint interface.
I made a darker version of the TVP Mirage interface. It's a bit easier on the eyes I find, especially when working on a Cintiq.
- Dark-Mike-Interface.zip
- (661 Bytes) Downloaded 644 times
- schwarzgrau
Since you can't change the buttons to white, I feel more comfortable with bright layouts. I created another one, based on lemecs surreptitious* dark colour theme.
I tried to reduce the layout-elements to the minimum, to make it a bit clearer. Unfortunately like in lemecs interface unchecked checkboxes become invisible.
C Y A N B I T bright
Here you can see a fullsize screenshot (At home I only got the demo of TVPaint)
- cyanbit_bright.zip
- (539 Bytes) Downloaded 579 times
- elmisilhumano
I'm working with the new color scheme and wondering can I change the color of bar on top of the tvp window?
M.
M.
- Screen Shot 2014-03-12 at 11.10.44.png (57.68 KiB) Viewed 13195 times
Mikko Vormala
Nope, it depends on your OS.
(Nice color scheme BTW )
- elmisilhumano
Just came my mind because in phototshop it's dark.Elodie wrote:Nope, it depends on your OS.
I'm going to share it when I'm happy with it. It's quite hard to find what is what. Need a map..or at least a preview and undo.Elodie wrote:(Nice color scheme BTW )
M.
Mikko Vormala
As said elsewhere : yes, we should improve this part of TVPaint, but we have other more important request to add / fix
- elmisilhumano
Here is my latest interface. I use magic number 17 for the flat look.
EDIT: Small tweaking done.
M.
M.
- elmisil_dark.ini.zip
- (621 Bytes) Downloaded 578 times
Mikko Vormala
Amazing; where did you pick that number up ?elmisilhumano wrote:Here is my latest interface. I use magic number 17 for the flat look.
M.
- elmisilhumano
From Asaf.Paul Fierlinger wrote:Amazing; where did you pick that number up ?
M.
Mikko Vormala
That makes sense; he knows more about TVP's Interface that any of us.
- schwarzgrau
EMERALD DARK
This is a theme for Version 11. It's a bit darker than Orage, the original dark theme and uses just a tiny bit of color, to highlight some things.
- emerald_dark.ini
- (1.54 KiB) Downloaded 590 times
- elmisilhumano
A new screen shot with the new interface for my old elmsil_dark theme you can find here viewtopic.php?f=11&t=1313&start=30#p71632" onclick="window.open(this.href);return false;
M.
M.
- Screen Shot 2015-02-05 at 13.34.01.png (120.72 KiB) Viewed 13090 times
Mikko Vormala
So did you receive the downloadlinks for TVP11?
Cause it looks like you are working with it.
