What video WILL import into TVP?
Hironori Takagi
Re: What video WILL import into TVP?
Post by Hironori Takagi »
I can import both files without any trouble, too.
TVPaint11.0.9 / Windows10
Have you tried initializing the settings?
dgrantham
Post by dgrantham »
Thanks for the suggestion of intitializing the settings Hironori. I didn't know there was a way to do that. Will I find it in the manual?
TVPaint10Pro10.5.7-64bit :
-Lenovo ThInkpad P17 Gen2 Xeon W-11955 @2.61Ghz, 64GB, NVidia RTX A5000
-HPZ400, 6GB, NVidia Quadro 2000, Matrox MxO2
-Lenovo Legion Laptop i7700 2.8Ghz GTX1050 16GB
TVPaint Android:
-Galaxy Note 12.1
dgrantham
Post by dgrantham »
Actually a search for the word "initialize" doesn't come up with anything in the manual.
Usually this means deleting the settings file somewhere in the bowels of C drive and letting an app recreate it the next time it starts. Maybe someone can verify that.
TVPaint Android:
-Galaxy Note 12.1
dgrantham
Post by dgrantham »
TVPaint Android:
-Galaxy Note 12.1
dgrantham wrote: 15 May 2020, 08:24 Actually a search for the word "initialize" doesn't come up with anything in the manual.
Deleting a configuration and creating a fresh configuration can sometimes fix issues. Be sure to back up your custom brushes, keyboard shortcuts, etc. before deleting your current configuration , so you can restore your custom settings in the new configuration . Here is where deleting a configuration is mentioned in the User Manual :
https://www.tvpaint.com/doc/tvp11/index ... nces-start
* When a configuration is deleted, all effects, brushes, palettes, shortcuts… used previously will be lost. Of course, if you saved them in advance, you can reload and re-use them.
By default, the configurations are located in the folder :
- for Windows users :
C:\\Documents and Settings\\your_name\\Application Data\\TVPaint Animation 11 (pro)
- for Mac users :
Home Directory/Library/tvp animation 11 (pro)/
(be careful, Libraries are hidden on Mac Lion, Mountain Lion and Yosemite)
- for Linux users :
Home Directory/.tvp/
(be careful, .tvp is a hidden folder)
Just to tune in regarding the config folder, the next release of the software will include a button that will open an explorer/finder window directly to the folder where the config is stored, so you won't have to find the folder by yoursef and find a setting to show hidden folders :)
dgrantham
Post by dgrantham »
The directory is a little different on WIndows 10, but I found and deleted the config.ini file and restarted TVP, and there's no improvement.
TVPaint Android:
-Galaxy Note 12.1
dgrantham
Post by dgrantham »
I've tried test video downloaded from a site providing test video. It won't open in TVpaint either.
I had previously missed, in a post above, the suggestion that VLC could convert my files which might work, but that procedure has no effect - it doesn't create new files. This may indicate a system issue wrt to codecs; but as mentioned, WMP plays the non-importing files without issue.
It's also worth mentioning that this issue is consistent on both my machines, one of which is running Windows 7 and one running Windows 10. I've never installed codecs on either of these machines, but the performance of these files on WMP is fine on each computer.
TVPaint Android:
-Galaxy Note 12.1
dgrantham
Post by dgrantham »
I filed a support ticket about this over a week ago but haven't heard back. Not sure how to proceed.
TVPaint Android:
-Galaxy Note 12.1
Xavier
Post by Xavier »
Sorry I'm a little out of time, but I don't forget this issue. Several users complained about the video formats, mp4 and so on.
Yet I tried the videos you submitted, they were all imported successfully on my setup : TVP 11.0.10 on Linux 64 bits, using Menu File->Open/Import
I'm going to test again on a Win10 machine and see the result.
Xavier
Post by Xavier »
Update : on my Win10 machine, using TVPaint 11.0.10, the videos were imported successfully, on both Pro and Standard versions... sorry :(
This machine is freshly installed, with nothing fancy on it.
dgrantham
Post by dgrantham »
I would like to fix this.
TVPaint Android:
-Galaxy Note 12.1
Xavier
Post by Xavier »
If you use TVPaint 10.5.7 as your signature says, TVPaint doesn't support this version anymore.
Otherwise if this happens with the latest TVPaint 11, we will need further info to reproduce the error. There are serious hints that your problem is related to your Windows installation.
In any cases, the videos DO work on everyone else's machines.
So could you please try on another machine ?
dgrantham
Post by dgrantham »
Thanks Xavier.
I have had to work around this problem for the past short while. Taking a look again.
On trying another PC:
I am not sure how to acquire yet a third computer for a test. If you really think yet a third machine is necessary to test, please let me know what sort of PC I should try, and - if it were to work on this third machine - how we would apply that knowledge to one of my two computers. I need to work with video on TVP on one of them.
I would prefer to assume at this point that it works on other machines, as we have heard from others. Perhaps you can help me now - without further testing on yet another machine - look into the TVP/Windows/codec interaction where the problem may be solved on one of my computers. Or at least point me in the right direction. I don't know where to start.
Over my years on the Mirage beta team, video always loaded smoothly in XPpro so for some time I thought the issue w TVPPro was surely somewhere in my windows 7 computer. It has only been since the precise problem has now been present on a new windows 10 machine as well, that I began to think it was related to TVP.
I expect it is a problem with the way windows and TVP and codecs are relating together in my installations, which I endeavour to keep clean as possible to run AVID on the windows 7 machine and demanding 3D modeling software (Rhino) on the windows 10.
TVPaint Android:
-Galaxy Note 12.1
Xavier
Post by Xavier »
Xavier wrote: 27 May 2020, 12:32 If you use TVPaint 10.5.7 as your signature says, TVPaint doesn't support this version anymore.
Which version of TVPAINT do you use ?
http://forum.tvpaint.com/viewtopic.php? ... 45b94b0d76
