Weird : it seems like MacOS is actually preventing the save operation.heriz wrote: ↑18 Aug 2022, 00:25Thank you so much jon2, this solution just saved my bacon. I was minutes away from Force Quitting and losing a day's work with a deadline tomorrow. I don't know if it's related, but I realised (at the point of the freeze) that Autosave had also stopped working, so I had no backups eitherjon2 wrote: ↑03 Jun 2022, 00:26 Here is what WORKED for me:
I was encountering the same issue on my Mac. (Catalina)
On my other Mac (Big Sur) everything works fine.
My SAVE window would freeze. If this is also your problem,
you can rescue your project by doing this ->
Open your ACTIVITY MONITOR
TV PAINT will (probably) be first in the ENERGY tab.
You will find two TVPaint tasks, the first one is the application itself, the second one is called apple-something. That's the one that is trying to save your file.
Quit it.
Now via preferences -> interface -> go from SYSTEM to TVPAINT. The unusual looking TVPaint dialog box works (although I get weird issues with some letters??)
Definitely needs looking into!
Cannot save!
Re: Cannot save!
Re: Cannot save!
Would you mind trying this procedure ?
https://discussions.apple.com/thread/2017301
Re: Cannot save!
I switched back to System to check. It's:
com.apple.appkit.xpc.openAndSavePanelService (TVPaint Animation 11 Pro)
Re: Cannot save!
That's exactly what it was doing. Worth noting that as far as I know, I'd not made any system change that might cause this; no updates. Might have been in the background tho. I've been using TVPaint constantly over the past 2 weeks with no issues, then suddenly yesterday it did this.Xavier wrote: ↑18 Aug 2022, 07:53Weird : it seems like MacOS is actually preventing the save operation.heriz wrote: ↑18 Aug 2022, 00:25Thank you so much jon2, this solution just saved my bacon. I was minutes away from Force Quitting and losing a day's work with a deadline tomorrow. I don't know if it's related, but I realised (at the point of the freeze) that Autosave had also stopped working, so I had no backups eitherjon2 wrote: ↑03 Jun 2022, 00:26 Here is what WORKED for me:
Quit it.
