mox gallery
mox
Re: mox gallery
Post by mox »
Just testing a quick idea mixing a Classic Circle Transition with the new and powerful Brush Spreading (both in the FX stack/TVP11).
First I rendered the transition's frames then used the same layer to spread the leaves/brushes on it.
Jerome Lorin
Moxica (playground)
(Win11/TVP 12.0.3 pro)
Re: mox gallery
Nice one. You got the idea behind this FX. We will put some other exemples in the online manual soon.
mox
Re: mox gallery
Post by mox »
Still playing with the Brush Spreading :D
Jerome Lorin
Moxica (playground)
Re: mox gallery
I'm glad you like it. :)
here is a Before/After result that will be added in the online manual soon (click to enlarge and appreciate the difference)
Before (photo)
Before (photo)
After using Brush Spreading
EDIT :
Here with an other brush created by Léo :
Re: mox gallery
Here are my own attempts :
Original picture I have taken in Japan
An attempt with brush spreading
An another attempt, using brush spreading + convolution grid
But Brush spreading works also pretty well with animation (animation by Chad Essley) :
Original animation
After applying brush spread on the sun rays.
mox
Re: mox gallery
Post by mox »
Brush Spreading = Total playground :mrgreen:
Jerome Lorin
Moxica (playground)
Re: mox gallery
So true :mrgreen:
Sewie
Re: mox gallery
Post by Sewie »
Fabrice wrote:I'm glad you like it. :)
EDIT :
Very interesting, this!
Re: mox gallery
i'm testing brushspreading to see if i can use it for animated textured coloring.
but i get crashes when i set dispersion to low. when set to one tvpaint whites out and never comes back to life! :?
mox
Re: mox gallery
Post by mox »
Peter Wassink wrote:but i get crashes when i set dispersion to low. when set to one tvpaint whites out and never comes back to life! :?
No crash so far, but low "dispersion" value means high CPU usage indeed and it can take ages.
I wonder if it would be possible to stop (or pause) a processing during a preview. Tricky.
Jerome Lorin
Moxica (playground)
Re: mox gallery
mox wrote:... I wonder if it would be possible to stop (or pause) a processing during a preview. Tricky.
+1
[Esc] key (should) could do that imo .
