SplatterBrush!
Re: SplatterBrush!
Well, force the install, to be sure =)
It works well on my mac.
- masterchief
Re: SplatterBrush!
cheers... thanx for the brushesmalcooning wrote:sorry guys, didn't see those posts for some time now - I was on holiday.
Well, I'm back, and here are new year brushes!
(In the panel you'll find 2 brushes: Bristler - paint with this one initially, and Grunger - use it to mix and add some character. The purple colors are to be excused)
EDIT: for a better usage, remove the color command lines from both brushes' custom button commands, and then it won't reset to purple colors every time you select these brushes. If you struggle i'll upload a color-less panel)
enjoy
regards,
William
TVPaint Animation Pro v11
Re: SplatterBrush!
THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU ......Did I say THANK YOU! So much gratitude.
- CartoonMonkey
Re: SplatterBrush!
You're welcome, x1000!
- lapprenti roi des singes
Re: SplatterBrush!
Damn ! How come I missed this awesome thread !?
I Feel really grateful for your sharing, man ! You just answered some of my most anticipated requests !
Thanks a lot !
Thanks a lot !
- CartoonMonkey
Re: SplatterBrush!
Oops! I had mistakenly taken down my SplatterBrush V3.
Here it is!
http://www.cartoonmonkey.com/SplatterBrush-V3.zip" onclick="window.open(this.href);return false;
Here it is!
Re: SplatterBrush!
Hi, I realise this is an older thread but I can't download the splatterbrush V2 and V3, just the V1 is still available. Is it still possible to get them? Thank you
TVP 11 Pro (11.0.8-64 bits), MacOS 10.13.6 - Wacom Cintiq 27 QHD
- CartoonMonkey
Re: SplatterBrush!
Here they are!
attachment=0]SplatterBrush-V2.tvpx[/attachment] [
- SplatterBrush-V2.tvpx
- (16.6 MiB) Downloaded 855 times
Re: SplatterBrush!
Great! Thank you!
Re: SplatterBrush!
These brushes are great - my personal favourite is the Pressure Splat.
Many thanks.
Many thanks.
iMac (Retina 5K, 27-inch, 2020). 3.8 Ghz 8-core Intel Core i7, 128GB 2667 MHz DDR4. MacOS Catalina 10.15.7.
TVPaint Animation 11 Pro (11.5.2-64 bits).
Wacom Cintiq pro 24". Driver using 6.3.43-3 (avoiding 6.3.44-1)
John from Newcastle, johnfromncl Updated 2021-09-24
