TVPaint Animation 10.0 Feedback
idragosani
Re: TVPaint Animation 10.0 Feedback
Post by idragosani »
Sewie wrote:
Elodie wrote: Yes it is, because users asked us to have enlightened icons. So now, when you select a custom tool, it becomes yellow (with Lorraine's sky color scheme).
And for icons to disappear entirely? I'll post a screenshot later.
I had this issue yesterday after installing TVP 10 (on Linux), I restarted my machine and the problem went away. It might even get cleared by logging out and then logging back in, apparently there is internal configuration getting cached or something.
Klaus Hoefs
Post by Klaus Hoefs »
Concerning Audio and playsback speed (on MAC.)
I have an audio-file with 23.03 fps which I importet via the Clip:TimeLine, Load ...
I tried to animate with 12.5 fps and also with 25 fps.
so I called the Magic Number (1210) and set the congenial speed to my framerate:
in 9.5 it works, and in 10 it doesn't.
So is Magic Number killed, and if so - how can I put the audio-files to go with 12.5 fps ???
__________________
http://www.khoefs.de
Hervé
Post by Hervé »
Klaus Hoefs wrote:Concerning Audio and playsback speed (on MAC.)
In the preference panel -> Sound tab -> Scrub duration
Hervé ADAM, TVPaint Team
Klaus Hoefs
Set Scrub Duration to 12.5, set Playback Frame Rate to 12.5, pressed the Playback Preview button:
No that doesn't work. It sounds like a frog singing.
__________________
ematecki
Post by ematecki »
Klaus Hoefs wrote:It sounds like a frog singing.
With the weather we have right now here it's normal frogs are singing :)
Scrub duration should be minimal, such as 0.10. It is just for mechanical scrubbing duration; how long you want to hear the sound after you stop advancing the cursor. It is not a playback setting.
Eric Scholl
Post by Eric Scholl »
Is your sound too fast or too slow ?
The scrub duration defines the duration (not the speed) of the sound played when you switch from one frame to another. ( I don't know if you will understand, it's strange to explain ) . 0.2 should be enough.
Klaus Hoefs
Yes that's right - so is there a chance for audio playback @ 12.5 in preview-modus. -?-
(@Eric: From the rural children and from the meadows , I heard of cows who gulp frogs from time to time by accident...)
__________________
Klaus Hoefs
The playback at 25 fps is (-of course-) a little too fast (just like a eunuch singing), I think, because of the audio file is 23,03 fps.
At 12.5 playback speed of the clip it is frog-sound.
In 9.5 I could fix it with Magic Number.
I am not speaking of scrubbing. So it also doesn't help to set it to 0.2 (Scrub Duration in Sound/Pref)
__________________
ematecki
Post by ematecki »
Klaus Hoefs wrote:I have an audio-file with 23.03 fps which I importet via the Clip:TimeLine, Load ...
An audio file doesn't have fps...
What is its sampling rate ? (that's expressed in kHz)
Load it in some audio editor (like audacity) and see what it is.
Then set the same value in TVPaint (Preferences > Sound > Sampling Rate).
If it is in some strange sampling rate that isn't in the popup, convert it in audacity to one of the supported values.
If it still doesn't work, send me the file.
(o)_(o)
.`___'
./ _ \
(_) (_)
Klaus Hoefs
Sorry, meant the data rate, which is 2303.44 kBit/s
Sampling rate: 48.000 kHz
Format: wav, 24 Bit Integer (Little Indian), Stereo
(QuickTime gives also this informations.)
And yes Sampling Rate is set to 48.000 kHz in TVP.
The original file would be too large (2.89 GB), so I made a new smaller one (same proplems here) without drawing, only with sound.
And as same with the large file, if I put the playback frame rate to 23,000 it works fine, with 25 it's too fast (high).
I'll send you PM with a link asap.
__________________
andomori
Post by andomori »
not what it looks like
andomori wrote:not what it looks like
Hi andomori,
Please can you introduce yourself ?
Regards,
Fabrice.
andomori
Post by andomori »
oh, sorry.
I'm just a animation student.
is it just me or this icon looks like another thing?
idragosani
andomori wrote:is it just me or this icon looks like another thing?
It looks like a finger to me...
