Export TVPaint - Import After Effects 1.0.4
Mads Juul
Re: Export TVPaint - Import After Effects 1.0.3
Post by Mads Juul »
Jean / Folimage wrote:Thanks a lot, it's work!
It was because of my french :D
Glad it works :D .
Hi Jean,
Nice to see you in the forum, after we discussed about it. :)
I'm glad this script was useful for you.
See you during the Cartoon Movie tomorrow.
juansolimar
Post by juansolimar »
wow. this is amazing!
but, it wont be better if the script export in PSD?
what are the advantage of use this script instead of export "clip: layer structure"?
Mads Juul
Post by Mads Juul »
juansolimar wrote: but, it wont be better if the script export in PSD?
I could make it work with png. Not with psd. For several reasons.I dont have scipting access to the funcion export clip:layer structure for instance
juansolimar wrote:wow. this is amazing!
You can import the exported png into after effect and keep the timing with the included after effects script. You cannot do this with clip :layer structure.
But it is a personal taste , choose what you find the best.
Kind regards Mads
8ball
Post by 8ball »
Hi there, i would like to use/test this script but i dont know what to do with those files inside .zip file that i downloaded cause YT video is private.
Can someone tell me what to do with those files?
Mads Juul
Post by Mads Juul »
8ball wrote:Hi there, i would like to use/test this script but i dont know what to do with those files inside .zip file that i downloaded cause YT video is private.
I will make video avaleble again latest monday
-mads
8ball
Post by 8ball »
it will be right on time,
tnx m8 ;)
Mads Juul
Post by Mads Juul »
The Video Should be availeble again
-Mads
8ball
Post by 8ball »
ty again
Every time I try to export my project with your script I got a folder for every of my four layers, in every folder is the layerinfo txt file but only in one of the four are images.
I attached the TVPaint file, maybe you could tell me what I'm doing wrong.
Kreal_01_2.zip
(2.2 MiB) Downloaded 486 times
Mads Juul
Post by Mads Juul »
schwarzgrau wrote:Every time I try to export my project with your script I got a folder for every of my four layers, in every folder is the layerinfo txt file but only in one of the four are images.
The script only export whats between mark in and mark out. and there is only images on the lowest layer
Oh that's something I should have noticed. Thank you Mads
Mads Juul
Post by Mads Juul »
No problem :)
Lukas
Post by Lukas »
Great work on this script! Halleluja!
A question: What could be the reason my layers are in the wrong order in AE? (They are all there, except their order seems random)
  • Lukas Sketch Panel
  • TVPaint Pro 11.7.3
  • YouTube.com/@ClubBaboo
  • YouTube.com/@FrameOrder
Mads Juul
Post by Mads Juul »
Lukas wrote:Great work on this script! Halleluja!
I cant remember if i fixed the import layers in rightorder
Can you post screenshot of layer orders in Tvp and layer order in Ae. And whar version is your Ae?
