problems with save/export folder
Joost
Re: problems with save/export folder
Post by Joost »
the second time I export the image sequence the name will be set as Seq_01_SC_05_001.jpg .
That's what I would like tvpaint to do, but it only happens sometimes. It looks random to me (although I'm sure it can't be random). Sometimes "untitled", sometimes the right name (and even sometimes, not very often, a ".tvp" suggestion...)
TVP Pro 11.7.1
Lukas
Post by Lukas »
What if, instead of Untitled.png it would always suggest TVP-filename_[#####].png? (with 'TVP-filename' being the name of the TVP file, and [#####] automatically being replaced by the correct frame number)
Having 001 at the end of a filename with auto-counting seems nice, but when you export only a part of the animation using Mark In/Mark Out and you forget to put the correct frame number manually, it renders with completely wrong framenumbers.
It would be nice if this would be addressed as well.
(Using [#####] in filenames was mentioned in another thread earlier, but I couldn't find it)
  • Lukas Sketch Panel
  • TVPaint Pro 11.7.3
  • YouTube.com/@ClubBaboo
  • YouTube.com/@FrameOrder
