PPalette 7.50 (Mac/PC)
Gravin
Re: PPalette 7.50 (Mac/PC)
Post by Gravin »
never mind I worked it out :oops:
Just needed to add "script=Startup.grg" to the shortcut used to launch TVPaint and all is well...
lemec
Post by lemec »
Gravin wrote:never mind I worked it out :oops:
Ah, fantastic! Sorry I missed your last response. :o :D
(Win7x64, TVP Pro 11 32-bit)
TheQuestionMark
Post by TheQuestionMark »
Is there Windows 7 64-Bit Version for TVPaint 64-Bit? It doesn't seem to work. I installed it at "F:\Program Files\TVPaint Developpement\TVPaint Animation 10 Pro (64bits)\plugins', Restarted TVPaint, and Look at 'Windows -> Plugin ->' . The PPalette isn't there.
Animationriver
Post by Animationriver »
Hello!
Good day! )))
Mas os Sierra 10.12.5
How i do install Perceptual Palette?
Put files from this forum in a folder
Mac/applications/TVPAaint Animations 11 Pro.app/Contents/Resources/plugins
But (Windows-plugins) there is no this tool Perceptual Palette.
Please help!
Thanks.
Mark's Plug-in works only on PC.
Animationriver
Mac os Sierra 10.12.5
Mark's Plug-in works only on Windows.
lam giang
Post by lam giang »
thank you! :)
Does PPalette ever work for Mac ?
A history from this thread:
lemec wrote: 27 Jun 2011, 16:50
Elodie wrote:
chatbraque wrote:… but, for the PPalette… is it running on Mac now, or is it me* ?
nope, it's for PC only. :cry:
Unless someone wants to compile it...
Then Fabrice wrote:
Fabrice wrote: 29 Jun 2011, 16:33 Eric has compiled it on Mac . :)
I took a look to the options I usually use in the PPalette, and it seems to be working .
And Eric wrote:
ematecki wrote: 30 Jun 2011, 09:03 Mac version available. See very first post of this topic to download it.
Enjoy !
Here is how it appears in the first post :
Start edit by eric:
DOWNLOAD (Mac Universal)-->PPalette.bundle.zip
Sorry no .tvpx, because there are access rights problems if you are not the administrator of the computer...
To install it:
- unzip to get PPalette.bundle
- right click on you TVPA application (not on the icon in the dock, but the App usually in /Applications)
- select "Show Package Contents", this opens a finder window.
- navigate to "Contents > Resources > plugins"
- copy PPalette.bundle there (there sould already be some .bundle files there)
- enjoy !
End edit.
Then sometime later in this thread someone else asked how to install PPalette on Mac and they received this answer :
Fabrice wrote: 03 Jul 2017, 11:25 Mark's Plug-in works only on PC.
Elodie wrote: 03 Jul 2017, 13:18 Mark's Plug-in works only on Windows.
Because Fabrice and Elodie are no longer here, my question is addressed to Eric Matecki:
In the first post of this topic, you added a Mac version of PPalette. The files are still there to download . A friend of mine wrote to me: "I downloaded the PPalette.bundle and copied it to Contents > Resources > plugins as in the directions , but it does not appear in TVPaint 11.0.8 under Windows > Plug Ins." I also tried it and I don't see PPalette listed under my plug ins after copying the PPalette.bundle, so I am assuming the Mac version you compiled way back in 2011 was for TVPaint 9.5 or TVPaint 10 (what version were we up to in 2011 ? ) but it no longer works on TVPaint 11.
QUESTION: Will you ever be able re-compile PPalette for Mac to work with TVPaint 11 ? I hope so. But if not , or until that can be done , it seems to me that the first post in this thread should be edited again to remove the non-functional Mac PPalette bundle and make a note in big, bold letters: "PPalette plug-in is currently for WINDOWS ONLY" (and the title of the thread edited to read: PPalette 7.50 (Windows only) , instead of PPalette 7.50 (Mac/PC) . )
Kylerk
Post by Kylerk »
From a small experiment . This does work on 11.0.9 but only the 32 bit version. I tried 64, and it just wouldn't show up.
I don't really know if 64 bit is really necessary for any work I do, so I"ll just stick to 32 bit.
Kylerk
Post by Kylerk »
The new dongleless version of TVpaint doesn't seem like it offers support for 32-bit Tvpaint anymore.
Does anyone know how we could go about compiling this plugin for 64 bits? The source code appears to be available in the original post, I looked at it a bit, but I didn't understand what was there well enough to make any progress on it.
Is Lemec still around? Could he recompile it?
I use the pressure sensitive color picker all the time and really don't want to lose it. :(
TVpaint devs, could you help? Would me getting access to the TVPaint SDK let me compile it?
Thanks
lemec
Post by lemec »
Hi, I'm still around. I was having difficulty compiling it for 64-bit a while back and gave up. I'm working right now but later tonight I'll try again to try and track down what it was that I was running into.
Kylerk
Post by Kylerk »
That would be awesome Lemec! Pressure sensitive color picker is a feature all art programs need!
lemec
Post by lemec »
Ok, I remember why I had problems with the 64-bit... The thing builds the DLL but it crashes when loading. I think I might need an updated 64-bit SDK.
lemec
Post by lemec »
OK, so apparently the SDK hasn't been updated in years. Ugh. I dunno what more to do. It's kind of out of my hands because I can't invoke any native functions in TVP without it crashing.
