TVP Animation 9.5.21 is now available !
TVP Animation 9.5.4 is now available !
-Fix panel bin priority bug after a drop.
-Free hand stroke: apply the brush even when the cursor doesn't move.
-Fix a little bug in the registration panel
-fix script cmd: typo in tv_getactiveshape
-Fix Position tool: reapply
-Fix a possible dead lock with the camera previous
-better render of the camera thumbnail preview.
-TVPA Standard version: Add Export clip in the file menu
-script cmd: tv_listrequest can open sub menu ( with '/' in the name )
-Mac OSX 10.6: fix ICA
-Modify project: Fix rounding bug ( multithread/SSE )
-Modify project: keep faux-fix ( only if the frame rate and field mode don't change )
-Add Camera option in the EDL export
-Fix white artifacts in the project window.
-Fix Save project shortcut.
-Export EDL now save the config.
-Export EDL correct framerate.
Enjoy it !
You wanna test it ?
TVP Animation 9.5.5 is now available !
-Fix canvas rotation
-Add cmd: tv_layerblendingmode layerid [Color|Behind|Erase|Shade|Light|Colorize|Hue|Add|Sub|Multiply|Screen|Replace|Copy|ReplaceSet|Difference|Divide|Overlay|Light2|Shade2|HardLight|SoftLight|GrainExtract|GrainMerge|Sub2|Darken|Lighten|Saturation]
-Fix gif export preview
-Fix save fxstack in TVPP files
-Fix close button in the last project Project Tab
-Change layer density is now undoable
-Fill expand/range/gap value tool fill grabbed in a custom panel
-change blending mode use layer selection
-loop mode in shortcut Next/prev clip
-fix Peg hole tracker crash when reference is close to the top of the image and test if the reference is empty
-Add cmd: tv_layerrecompteexposure ID [FrameStart, FrameCount]
-Add Cmd: tv_infobar text
Enjoy it !
Re: TVP Animation 9.5.5 is now available !
TVP Animation 9.5.10 is available !
-cmd: tv_layerdisplay layerid [lighttable on|off]
-bug with the the tool "cut a brush" fixed.
aaaaand....
Spoiler : suspense.... :
The feature Out of Pegs !
Enjoy it :D
Re: TVP Animation 9.5.11 is now available !
A new update of TVP animation is available.
This new update contains a feature which improve the Out of Pegs and fixes some bugs.
Enjoy it
Re: TVP Animation 9.5.12 is now available !
The new features in the 9.5.12 are :
TVP animation 9.5.12 is now available !
This new version fixes some bugs with the Mechanical Pencil and the Quicktime load.
Moreover, news commands with George Script have been added, you can now save all images and all layers in a multilayered PSD file when you export with the layers tab (and image selected)
aaand
(*suspense*)
(terrific, isn't it ? :mrgreen: )
The smoothing option is now available ! To find, just right click on the main panel=> a little window will appear with different options, whose the auto-smooth. :D
Enjoy TVP animation 9.5.12
It also should work with "Ink" on windows. It means that the pressure should be recognized on the N-Trig PC-Tablet-Touchscreen.
Re: TVP Animation 9.5.14 is now available !
TVP Animation 9.5.14 is now available :
-Fix grab mark out during playback
-Font UI is now full anti-aliased ( cleartype ) ( Windows )
-Drawing Smoothing -> Fix a bug in non-realtime mode when you click outside the canvas
-Fix Erode crash ( Mac only )
-Custom brush Smear: fix a rounding bug
-Japanese Windows: fix font size
-Japanese Mac: fix input method kotoeri
-Lighting FX: fix a bug when the light is very big and add dithering
-Fix a loading crash when project file is corrupted
-Fix a bug in the best pixel filter.
-the menu: layer->expo->faux-fixe is grayed when the current image is not an exposure.
-Japanese: fix some translations
Enjoy it !
(How that, "hey, there was not a 9.5.13... are you superstitious ?" In fact, TVP 9.5.13 was only available in Demo version, because of the problem with Japanese's font, that must be corrected quickly. Moreover, TVP 9.5.13 was available very a few days).
Re: TVP Animation 9.5.15 is now available !
TVP Animation 9.5.15 is now available :
-it fixes a bug with the HTML export for the Storyboards
-it fixes a bug in the New Project Panel, concerning the Aspect Ratio
Enjoy it !
Hervé
Re: TVP Animation 9.5.16 is now available !
Post by Hervé »
TVP Animation 9.5.16 is now available :
-it fixes japanese fonts ( windows )
-it fixes a bug in the Project Audio playback
-In the settings panel: add the choise to use wintab or Ink ( windows )
-Fix a bug in the filebrowser
-fix script cmd: tv_readtextfile
Enjoy it !
Hervé ADAM, TVPaint Team
Re: TVP Animation 9.5.17 is now available !
TVP Animation 9.5.17 is now available :
-You can now mark your images and switch between them.
-the Video grabber system has been improved on Mac ( works with http://agent.liquiddigital.com.au/" onclick="window.open(this.href);return false; )
-the Stroke's speed and reaction is improved on Mac.
-George scripts for the sound have been added
Enjoy it now !
Re: TVP Animation 9.5.18 is now available !
TVP animation 9.5.18 is no available !
Here is the changes list :
-Sharp drawing mode: apply on Alpha
-Add Lighten Only and Darken Only drawing mode.
-Speed optimization in the video-In panel.
-Audio file: Ask a new Path if the file is not found
-Fix a bug with new drawing mode shortcut
-Fix script cmd use localized name
-Fix crash after the creation of a project from a template
-Fix audio offset after a Clip Split
-Fix Envelope offset after a split Project track to Clip tracks
-New option in the FXStack panel to apply only on Heads :D
-Fix PSD 8bits gray scale
-Fix XSheet Source: image sequence can have more than one frame
-Add new tool blending mode: Dodge and burn
-Enhance Sharp mode
-Wrap tool : use best antialising
-Change Image mark color with a script cmd: tv_layermarkset layerID imageNumber ColorIndex
-Add shortcut to play your animation from the current image
Enjoy it now !
Mike
Re: TVP Animation 9.5.20 is now available !
Post by Mike »
TVP animation 9.5.20 is now available !
_ The main change is the load / play audio on Mac OS X (fix bug of the last version of QT)
_ No more crash during acquiring a video frame
_ Many many other small issues here and there (like mouse wheel on Mac OS X, ...)
_ Speed enhancement everywhere
_ The download includes a tvpx example
_ Linux: drop from the desktop
_ Linux: better management of the clipboard
_ Linux: audio playback
_ Linux: mounted folders visible in the file browser
_ Linux: double-click on a tvpp file in the desktop open the file inside the working TVPaint Animation
_ Linux: multi-monitors management
_ Linux: export/import tvpx no longer crash
_ Linux: icons fix in Unity
_ ...
Enjoy it now !
TVPaint Team
Mike
Re: TVP Animation 9.5.21 is now available !
Post by Mike »
TVP animation 9.5.21 is now available !
_ Fix bug in the spline 3pts refresh
_ Fix bug in refresh of the preserve transparency button
_ Fix bug in custom panel buttons background display
_ MacOSX: bug in the license registration in MaxOSX 10.7
_ Linux: bug in Linux AVI export
_ Linux: bug in the linux audio playback during scrub/play
_ Linux: Fix startup panel
_ Localisation Fix
_ Fix bug in the downloaded archive in MacOSX
Enjoy it now !
TVPaint Team
Locked
