What do you meanCharlieC wrote: btw- are there updates to 64 bit 10.0.9 that i should try first?
The latest version is the 10.0.11, if I'm not wrong.
When you install the second version (let's say : you installed the 64 firs and then, the 32 bit), just rename the 64 bit version like "TVP Animation 10 Pro 64" before installing the 32 bit version in your application folder.CharlieC wrote: if i mount the '32' does it overwrite the '64'?
and if so, what's the process for having both installed separately, and keeping their files from getting mixed up?
By the way, even if you name the both versions differently, they will use the same interface and the same configuration.
