WACOM Switcher 1.43 feb/03/2007
gurkoz >> okay, I made it switch the focus back automatically.
http://www.digitalartoasis.com/viewtopic.php?p=432#432
(Win7x64, TVP Pro 11 32-bit)
gurkoz >> This new version lets you turn off the autoswitching -- it will make the hotkey work even if the stylus is out of range.
version 1.42
+ option to disable autoswitching, for people who want to use hotkeys exclusively.
version 1.42
- malcooning
Lemec,
hotkey switching is fantastic. assigned to the third button on the pen it makes a world of difference!
you're such a hard worker. Congrats, and thanks a lot man.
One more question, thought ( ), when running the switcher, it opens the Wacom control panel obviously. I always click on the Switcher tray icon to hide the control panel, otherwise it takes the focus everytime I switch monitors. This is all fine, but I was just wondering if there's a way to start the wacom panel minimized to the tray to start with?
cheers again for fantastic work!
version 1.43
+ option to automatically minimize the control panel to the task-tray at startup for Intuos and UD tablets
# fixed problem with working directory -- now config file INI and WAV files are all referenced from wherever the wacswitch.EXE is located.
i am trying the latest version
it works great with tvpaint but i noticed when i click another aplication it switched back to my old setting.thus throwing me off my orientation
i tried to find a menu item to make the wacomswitch work globally (for all my programs) i just looked in the options and ticked 'disable autoswitching' in the options, thinking this might prevent switching the settings between aplications
(i never read manuals i just guess and try) offcourse this did not solve my problem....
however... i did find a bug(?):
'disable autoswitching' cannot be switch back on in the options panel.
if i try to remove the tick it keeps saying "Automatic switching disabled"
and the option remains active
i see...managed that
but now the rest
Marc i am not becomming friends with the wacom switch..
the thing isn't working for me...it drives me nuts!
the thing is...it has worked before but now i see the wacom panel flickering on every attempt to switch monitors
and i still have the problem that the wacom settings are reset when i make another open aplication active.
so the distances my pointer travels in relation to my hand changes constantly
..when i look in the wacom panel i see the function of the first penbutton is getting reset from my preferred "right-click" to "middle click" ?
and when i change to monitor two it changes to "4th click (backwards)"
going back to monitor 1 its "middle click" again!?
but now the rest
It's possible that your original shortcut that you used to launch the wacom switcher didn't point to the right directory so your INI file wound up going to the wrong place.
The latest version fixed that so you probably have to re-run the "set combobox" function. Also, you should click the task tray icon to hide the wacom control panel or turn on the auto-hide function.
