about light table off pegs behavior Topic is solved
Soom
Post by Soom »
There is a tiny strange behavior when using the off-pegs on the light table. whenever a peg is altered, all other selected pegs shift in color - become darker. First I thought it's a glitch, but then I thought it might have been done on purpose, which is a good purpose, but wouldn't it be more intuitive that instead all other drawing shift colors - the selected drawing would change?
thanks
Re: about light table off pegs behavior
screenshot please. :)
Soom
Post by Soom »
Fabrice wrote:screenshot please. :)
You are right - sorry! here they are.
Without using out of pegs:
no oop
no oop
As soon as I select one frame for out of pegs manipulation, all other frames become darker:
with oop
with oop
Here you can see the selected frame did not change in color. I like the idea of distinguishing the manipulated frame, but IMHO it should be vice-versa
oop moved
oop moved
I noticed the same behaviour
Sewie
Post by Sewie »
Yeah, I recognize it too.
Soom
Post by Soom »
This bug is even more serious - I realized it when working with more solid dark colors. When one of the frames on the light table is shifted, the other one overlaps the drawing (look at the screenshot). Interesting, that if both frames are shifted, it behaves normal again.
Maybe you have turned the lighttable to "front-mode".
If you click on Instance see if "Blend to front" is checked.
Bildschirmfoto 2016-10-12 um 19.43.12.png (16.32 KiB) Viewed 21546 times
MCohen96
Post by MCohen96 »
schwarzgrau wrote:Maybe you have turned the lighttable to "front-mode".
I have exactly the same problem. I've tried both, with "blend to front" checked and unchecked and to me it just looks the same. Are there any other options I could play around with?
OK ! I understooooood ! :D
So yes, indeed, there is a weird behaviour when you enable OOP on 1 instance (image becomes more opaque, for no reason).
To the To do list !
Soom
Post by Soom »
Elodie wrote:OK ! I understooooood ! :D
To the To do list !
Exactly!!! :) hooray, thanks!
It was really simple to get, but I don' know, I was very slow on this one...
EDIT : fixed in the v11.0.6
https://forum.tvpaint.com/viewtopic.php ... 450#p98450
