CSV format import/export script for Moho (Anime Studio)
Posted: 21 Jun 2016, 19:37
This is a menu script addon for Moho/Anime Studio (11 and above, but probably working with older versions too). It imports scenes in TVPaint's CSV format.
Unzip the file and copy the fa_import_csv.lua file into your Anime Studio contents folder, for example to the scripts/menu/Image directory. After starting Anime Studio, you can find the new "Import CSV animation..." menu item in the Scripts/Image menu.
It imports the contents of the file into a new Group Layer. Inside the group layer it creates Switch Layers with the image instances in them.
22 JULY 2016, Version 1.1: it can import document settings (field, fps, duration) now.
16 AUG 2016, Version 1.2: support for the Folder arguments of CSV 1.1 / Version 1.3: advanced search for the folder path
27 AUG 2016, Version 1.4: bugfix for empty frames, experimental export plugin 1.0
01 SEPT 2016: experimental export plugin 1.1: faster rendering, bugfixes
