QuickSave2 Button Set (updated version - July 14, 2016)
Posted: 07 Jul 2016, 18:41
Here is the QuickSave2 Panel update which lets you directly save single image files - Display mode (include all visible layers) or Layer mode (only the current Layer). You can also directly load image to the current Clip/Layer/frame.
Four Buttons for directly saving and loading the current Clip/Layer/Frame image to a designated folder of your choice. Here's what the four buttons do.
Set Path (do this first)
Lets you select a default path/folder, so the other buttons can save the current Display (includes all visible layers and opaque background) or the current Layer (with alpha mask, preserving transparency).
Save Display
Lets you save all visible Clip/layer/frames and opaque background into an auto-named, auto-incrementing file in the default path/folder. (default naming: TVP-Display00001.png or some incremental variation)
Save Layer
Lets you save the current Clip/layer/frame, visible or not, into an auto-named , auto-incrementing file in the default path/ folder. Alpha Masking of the layer image will preserve the transparency of the surrounding area. (default naming: TVP-Layer00001.png or some incremental variation) Updated to use NoPreMultiply for AlphaSaveMode - July 14, 2016
Load Image
Lets you load an Image to the current Clip/layer/frame. Loading a saved Display will have an opaque background. Loading a saved Layer will have a transparent background so that content from lower layers may show through. (default extension .png)]
If you have any problems (Mac PC or Linux) please post details and error-messages here, thanks!
EDIT: I've uploaded an updated version in which the AlphaSaveMode has been changed to NoPreMultiply (avoids fringing).
Please down load again and install over old version.
Save Display
Save Layer
Load Image
