[SOLVED] Using If functions to check a variable Topic is solved
I try to write a script, which checks if a stencil is active, but it seems I'm handling the request the wrong way.
//======= GET ID =======//
tv_LayerGetID 0
Lid = Result
tv_layerstencil Lid
PARSE result Lid STon STstyle
IF (STon == "on")
	PRINT "It is on"
ELSE
	PRINT "It is off"
END
If I PRINT STon I get "on" or "off", but I can't get the if function work, no matter if I write IF (STon == "on") or IF (STon == on)
Re: Using If functions to check a variable
when testing a string you need to use the compare command:
try:
IF CMP(STon, "on")==1
Thank you a lot, now it works.
ini
Post by ini »
IF CMP(Ston, "on")
ELSE
END
It works too.
Sorry I don't understand what you said. It wanted to say, that it works, after using the way Svengali described.
