moving images on multiple layers at same time Topic is solved
oellen
Post by oellen »
Hi,
Is there a way to lock layers together so when you move an image on one layer the other layer comes along with it? I have an animated layer and below it a COLO layer. I want to change my animation, but when I do the color layer gets all messed up and just fills the screen with color. I guess I can merge them together, but that kind of defeats the purpose of having a seperate COLO layer.
Thanks for the help.
Ellen
Cintiq 27 QHD
TVP 11.5.1
Re: moving images on multiple layers at same time
Select multiple layers with shift, then grab any image and drag: rest will follow.
oellen
Post by oellen »
I was going to say, that that didn't work for me. However, it doesn't work on panning, but it does work on transform. Thanks.
Cintiq 27 QHD
TVP 11.5.1
