how to save custom 3 Pts Spline tool? Topic is solved
furushil
Post by furushil »
I would like to create two buttons in a custom panel.
One for a regular stroke pen tool and another for a 3 Pts Spline pen tool. I cannot figure out how to do that. The button only saves the pen tool characteristics but does not differentiate between "stroke" and "3 pts spline" :|
Is it possible to have two different buttons for that?
Re: how to save custom 3 Pts Spline tool?
Create one stroke button with "grab current tool". Select this button and go to edit. Select a command before the end, select "Insert Command". Set this command to "Stroke > 3 point spline". Save, enjoy.
furushil
Post by furushil »
Thanks, that works!
kmvassey
Post by kmvassey »
Hi! I'm trying this technique now and can't seem to get it to work. I'm grabbing the current freehand drawing tool and then editing, inserting a command, and typing the custom command as shown above, but still only get the Freehand stroke. I'll try posting a screen grab of what I'm doing. Thank you!
Screenshot 2023-11-05 171258.jpg (35.84 KiB) Viewed 7705 times
You should not insert the line as a "Command". Remove that line.
Instead, insert a "key" by selecting Set KeyStroke, then choose "Shape:Spline 3Pts".
Then save.
This should now use whatever tool is set by line 0 and let you draw that as a 3 point spline line.
sven
kmvassey
Post by kmvassey »
Yes!! That worked great and makes total sense. Thank you so much! :)
