Issue with Out Of Pegs feature
Posted: 11 Aug 2016, 16:36
by BruceM
I'm attempting to use the out of pegs feature to check out how it works, but am running into an issue -- after I click on the dot under the light table slider to activate the out of pegs feature, and slide one of my 2 keys to line up with the other key, how do I then de-activate the repositioning so that when I go to draw the inbetween frame, it doesn't cause the repositioned key to continue to slide around as I move my stylus around?
-Bruce
Re: Issue with Out Of Pegs feature
Posted: 11 Aug 2016, 16:43
Just press Return.
Posted: 11 Aug 2016, 17:04
by BruceM
Thanks Slowtiger!
Posted: 11 Aug 2016, 17:20
by BruceM
One more question about Out Of Pegs -- once I've repositioned a key and done my inbetween drawing, when I click on the Out Of Pegs dot under the light table slider again, and try to reposition one of the drawings again, they seem to be unaffected. I'm not able to move the keys again. The box appears, but when I move it, the drawing stays in the same place. What am I missing here?
-Bruce
Posted: 11 Aug 2016, 17:54
Works here on my side.
LIghttable panel, click under slider, move drawing
click under different slider, move
return, draw inbetween
click on any O under slider, move drawing again
click X, return to normal.
