break and delete using delete key Topic is solved
Hi, how do i do it? TVPaint 10, i would use delete key to break and delete image. Now TVPaint 11, I don't know how anything works! What short cut setting can i set "delete" to, in order to make this work? Also, how can I set layers to include auto break and auto create instance? are there preferences?
Re: break and delete using delete key
See Manual, 3: Animating > working with instances > splitting.
Yes, breaking is not a problem. I guess the better question is, which "short cut" is the same as pressing the "skull and crossbones" in the main panel?
[Shift + K] or [Backspace] keys.
