Wacom Art Pen brush rotation not working
m-ries
Post by m-ries »
Hi!
When I make a custom brush in TVP 11 Pro and want to connect "angle" to "twist", nothing happens. I am using a Wacom Art Pen on a Cintiq 21 UX under Mac OS Sierra.
When I connect "angle" to "azimuth", everything works as it should. In other applications, stylus rotation is working correctly.
Thanks for your help!
Matthias
LyndaE64
Re: Wacom Art Pen brush rotation not working
Post by LyndaE64 »
Hello!
I have exactly the same problem as the OP. Is there a solution to this? I know it is nothing major but sometimes even the small things are frustrating. :)
Thanks in advance!
I can't have it either. But I remember this mode was created for specific pens on Inutos 3 and I'm not even sure it's compatible with newest ones...
Won't orientation do a similar job actually ? :oops:
Johannes
Post by Johannes »
Hi, is there any solution to this? Orientation is not doing the same thing. It is working fine on the windows side but nor on mac.
Best Johannes
hello,
What is you TVPaint version 11.x.x ?
What is your Wacom Drivers version ?
Johannes
Post by Johannes »
TVP Animation 11 Pro (11.0.6-64 bits) en
Wacom Driver:
MacOSX - Driver 6.3.15-3 (10.9x - 10.11x)
Cintiq DTZ-2100D/G*
* i bought in in 2008 and i never considered buying a new as it is/was flawless. I bought an 5k iMac and i cant use Windows as it is not capable of dealing with the pixel density difference between iMac screen and cintiq 1600x1200. The Wacom driver is the last that supports this old Cintiq model.
best
Johannes
