Reduce size variation of the brush Topic is solved
Eddytor
Post by Eddytor »
Hi, i'm just starting TVpaint, and i wanted to know if there was a way to change the size variation of the brush ?
I realise i'm probably not very clear, so let me explain:
When you are using a tablet, you can use the pression to change the size of the brush.
If your brush have a size of 10, and you press your pen hard, you'll draw a line with 100% of your brush size, wich is 10
If you press your pen very gently and softly, you'll draw with ~10% of you brush size, so you'll get a much thinner line (around 1 )
Is there any way to not have a 0% to 100% ratio, but rather a 40% to 100 % or 70% to 100% ? So that your line will have size variation, but not too much ?
I really have trouble drawing without it, i tend to be too gentle with my tablet and i end up have huge vartiations in the width of my lines.
And if this If this is still not clear, here's a picture, taken in photoshop.
Anyway thanks in advance, and sorry if i made mistakes, i'm not a native english speaker
Re: Reduce size variation of the brush
you are looking for the profile editor
every conection setting has a graph called profile, accesible by right clicking the connection button
see image
Eddytor
Post by Eddytor »
You sir, are awesome <3
