Hey,
I don't like the fact that newly exported files are put in the "recent files" menu. I usually only need the files I opened with TVPaint and the exported files confuses me to find the file I need to open
Nathan
Exported files in recent files
- NathanOtano
Re: Exported files in recent files
+1.
- schwarzgrau
+1 from me too
agreed, maybe a new item recently exported would make sense ?
or perhaps place this in the export panel.
+1
Yes, a drop down or pop up list of Recently Exported files in the Export panel makes sense.Peter Wassink wrote:agreed, maybe a new item recently exported would make sense ?
The listing of recently created and saved files is stored to and retrieved from the config.ini file each time TVPaint is quit or started.
I had the same negative reaction as Nathan, et al., to the different file types that fill up the list, so I wrote a utility last year that lets me choose from recently saved .tvpp files (only) which I upload here. I should note that the "TVPList" utility also attempts to filter out any path/.tvpp files that can no longer be found or loaded, unlike the Recent files listing.
Myself, I'd like to have a Preference checkbox that would offer the option to build and display a chronological list of saved TVPP files only.
- TVPList.tvpx
- updated Dec 4, 2016
- (83.5 KiB) Downloaded 2301 times
- NathanOtano
I wasn't aware you can do that <3 thanks for sharing sven
Update: Found a silly bug in the TVPList utility: the loading loop skips the most recently saved file.
I've updated the original TVPLIST.TVPX download file...
If you are using it, please download again and reinstall.
- NathanOtano
Thanks!
