COPY and PASTE image Topic is solved
paulom
Post by paulom »
Hello guys!
when I copy and paste an image on the layer the other images in front of it they all move ahead one frame, is there a way for this not to happen, so when I copy and paste everything would still the same except for the image that I pasted it.
Thank you,
p
Re: COPY and PASTE image
If you want to overwrite a frame with an image you've just copied, you must select that frame (underline it).
paulom
Post by paulom »
Hi Elodie,
I tried but still jump one frame to the right so let say i have 200 frames already made and in synk with all the layers above if I paste an image anywhere in the middle of those 200 frames the 100 frames on the right they all move I guess i have to create another layer paste that one frame on that layer and flat the two layers.
Do this:
- copy 1 frame.
- go to the layer you want to paste in
- click AND DRAG at the number under the frame you want to paste in
- this number will become yellow, means you've selected just that 1 frame
- paste.
paulom
Post by paulom »
COOL!!!!! That works!!!!! Thank you very much!!!
Thank you slowtiger for explaining in detail what I meant :D
