Playback short cut
Playback short cut
Hi, I want to be able to playback 3 instances (drawing, blank, drawing) with one hotkey button. I want to press the hotkey and when I let go it will automatically stop on the blank (middle) instance. Then I can draw on it. I can set the bookmarks, one before the 1st instance and one after the 3rd instance. Ok, that's easy. I am struggling to re-name the hotkey. There is a big long list of hotkey options and the one I pick is always wrong. We did this, it was demonstrated at CTNX so I know it can be done. I am afraid I forgot which hotkey to use. Any suggestions? Thank you.
Re: Playback short cut
Hello Trayvon5,
I have moved your topic in the appropriate section of the forum, Technical support.
Besides, we are going to need the following informations :
https://forum.tvpaint.com/viewtopic.php?f=10&t=6167" onclick="window.open(this.href);return false;When you have an issue with TVPaint Animation, please, don't forget to precise important details :
• What is your OS and its version :
- Mac OSX 10.7 (Lion), 10.8 (Mountain Lion), 10.9 (Mavericks), 10.10 (Yosemite)...
- Windows Vista, 7, 8, etc...
- Linux Ubuntu 10.04+, Debian 6+, RedHat Entreprise Linux 5+, Fedora 15+
• What is your OS architecture (32 or 64 bit) + CPU type and amount of RAM.
• What is your software version (for example : Mirage 1.5, TVPaint 9.5.21, TVPaint 10.0.11, etc...)
• What is your software edition (Standard or Professional)
• For the Professional Edition : What is the architecture (32 or 64 bit) ?
• What is your Wacom (or other brand) Tablet and drivers version ?
By the way, don't forget to repeat the details above EACH time you have an issue. We cannot remind the configuration of all our users![]()
(to save time, you can write the information above in your sign)
Moreover, don't forget that the more you will give us concrete examples with images or downloadable files, the faster we could answer you.
And finally, don't forget to say "Hello", especially when you post in the forum for the first time, we are not machines
He already did that: viewtopic.php?f=10&t=10012&p=93318#p93318" onclick="window.open(this.href);return false;
That was 6 months ago, maybe it has changed, and as said in the quoted post:
- NathanOtano
I don't fully understand the question, but maybe this script can help you : viewtopic.php?f=21&t=9582&p=88578&hilit ... nge#p88578" onclick="window.open(this.href);return false;
You select the instances you want to playback and then each time you launch the shortcut, it will playback the selected frames and then go back to your position. Meaning that if you're on your blank frame, you playback the 3 frames and then go back to your blank frames.
I assigned it to ctrl+space
You can also use the flip panel
