Hello People,
for a while now, I'm locking for a solution to get my Version 9.5 of TVPaint to work after
the anniversary update of Windows 10. As other ppl I get these error messages :
TVPaint has stopped working.
A Problem caused the Program to stop working correctly. etc...
*you know how this goes
When trying to debug it, Visual Studios tells me there is a problem
with the .dll and .pdb Data like followed :
Unhandled exception at 0x76555727 (SHCore.dll) in TVP Animation 9 Pro.exe: 0xC0000005: Access violation reading location 0xB774BEB6.
If there is a handler for this exception, the program may be safely continued.
This has been discussed around here but I couldn't find a solution to this so far.
Is there a fix by now or a work around i can use, I tried a lot and getting no results
so far.
How to get TVPaint 9.5 to work on Windows 10? Topic is solved
Re: How to get TVPaint 9.5 to work on Windows 10?
Create a new account where you will use TVPaint Animation only.
... or upgrade to version 11
Ok, ... so just that we are on the same page.
What kind of acc do you mean exactly? A new Windows acc ? Witch doesnt make much sense to me
since OS update is omnipresent on a mashine. I got two laptops, one is working with Win 8 and one with 10. The point is I wanted to get it to
work on my Win 10 Laptop. Plus I feel kinda cheated if I have to get an Upgrade to TVPaint 11 <witch aint free>, since everything was fine before that darn upgrade.
Downgrading Win 10 isnt an option anymore <only possible for ten 10 days, then u r screwed>, I consider reinstalling Windows 8 but still, not satisfying.
Again enlighten me about the acc pls. Ill definitly will try that. Thx and I hope there is something out there.
There is a topic where this issue with Windows 10 was covered in detail :
http://forum.tvpaint.com/viewtopic.php?f=10&t=10127" onclick="window.open(this.href);return false;
See that topic.
See that topic.
Alright, the new acc of Win 10 on my Laptop is able to run the App <Version 9.5, I also tried the 10 pro demo>.
Not the best Solution but it'll keep me in business for a while.
Thanks
Thanks
