Can't import any videos into TVPaint 11
MichaelJRuocco
Post by MichaelJRuocco »
I want to import some footage to draw over for my students, but for some reason TVPaint won't let me import any video footage files, no matter the size or file type (.mp4, .avi, etc.) When I select import/open in the file menu, or "import footage" in the layers area, an open window will pop up to select my files, and when I select a file and hit "open", nothing happens. Sometimes after hitting "open", the same window will pop up again, and after selecting the file, nothing will happen.
None of the other forum topics regarding importing video seemed to cover or answer the issue I'm dealing with. Is this a bug in the program, or am I not doing something right?
Windows 10 Pro N, Mid-2016
4.01 GHz Inter (R) Core(TM) i7-6700K, 32G of RAM, TVPaint PRO 11.03 - 64bits
Wacom Cintiq 24HDT
Re: Can't import any videos into TVPaint 11
Hello, welcome here. Please read this topic :
http://forum.tvpaint.com/viewtopic.php?f=10&t=6167" onclick="window.open(this.href);return false;
MichaelJRuocco wrote:I want to import some footage to draw over for my students, but for some reason TVPaint won't let me import any video footage files, no matter the size or file type (.mp4, .avi, etc.) When I select import/open in the file menu, or "import footage" in the layers area, an open window will pop up to select my files, and when I select a file and hit "open", nothing happens. Sometimes after hitting "open", the same window will pop up again, and after selecting the file, nothing will happen.
Hi, Michael ,
Good to see you here.
See Elodie's post above (they need your basic info: i.e. what version of TVPaint do you have ? 11.0.3 is most recent . Be sure you've updated to 11.0.3 . What is your computer OS ? etc. , as here : http://forum.tvpaint.com/viewtopic.php?f=10&t=6167" onclick="window.open(this.href);return false; , A handy way to do this is to go into your User Control Panel here on the forum , Profile > Edit Signature to add the information to your signature line . See mine below. )
When the Import Footage window opens make sure you are importing the footage as a Project (makes a new project of the imported movie) or Layer (adds the movie to a new layer within in an existing scene , or a Clip to add the movie as a new Clip (scene) to an existing project . Be sure you're not trying to import the movie as Custom Brush.
See the four different options for Import: Project, Clip , Layer , Custom Brush -
Screen Shot 2017-01-12 at 9.59.27 AM.jpg (29.55 KiB) Viewed 19384 times
MichaelJRuocco
Hey David and Elodie!
First off, my apologies for not providing my info. I added it to my signature, which should be on the bottom of my post, but just in case:
Wacom Cintiq 24HDT
As for Importing Footage, that Import window you posted doesn't come up. When I try to open a file to import, nothing will happen, but if I import something like a photo or even a .gif, that import footage window will come up. I'm not sure if it's just not properly reading the file formats for video. I've tried .movs (which I read up on in the forums and learned don't work), .mp4s, .avis, .m4vs... no dice. Not sure why the program doesn't go to the import window when selecting a video.
Wacom Cintiq 24HDT
In a situation like this I first check if other programs have the same problem. Do the videsos play on that machine? Is there a video editor, can it inport?
MichaelJRuocco wrote:Hey David and Elodie!
Wacom Cintiq 24HDT
Hi, Michael -
Well ,that mystifies me. I'm on Mac , but I have many students who work with TVPaint on Windows and I have not come across this issue you are describing . The expected behavior on both Mac and Windows is that if you select a .mov or .avi or .mp4 file -- or any compatible still image format such as .jpg, .png, .tiff -- from File Menu > Open/Import (or just drag & drop the movie file on to the TVPaint project window) then the Import Footage window will open , as shown here:
https://www.tvpaint.com/doc/tvp11/index ... image-anim" onclick="window.open(this.href);return false;
Hopefully someone from TVPaint development can help you figure out what the problem is.
