Get Camera Values Topic is solved
NathanOtano
Get Camera Values
Post by NathanOtano »
Hey!
I need to get Camera Values with george at a given position, even if there is no key point there.
Need it to script some functions related to camera values in time, like compensating a layer position to have have it still while the rest of the layers are moving with the camera. Or animating on the spot but being able to put it back where it was in the layout afterward.
Maybe just a way to invert camera values regarding current point, or something to stick a layer to the camera. But gorge would be usefull for everything with few efforts.
Nathan
Re: Get Camera Values
Just a thought: could you script to create a keyframe there, get its value, then delete the key again?
NathanOtano
I thought about that two but i can't set a key while keeping the current values :( I have to get the values first to set the key, even if there is no key at that point. It's frustrating cause you see them in the menu :)
Mads Juul
Post by Mads Juul »
done in v11.0.6
