I am using 10.5.7 32bit standard edition on windows 10. It worked fine last year.
I've seen suggestions that it might be a wacom driver conflict, but the problem persists even after uninstalling the wacom drivers. Any help would be appreciated, I need the software to complete a job.
This is the text of the error:
edit: I downloaded the TVP 11 demo and that works.TVPaint Animation 10 (32bits) has stopped working
A problem caused the program to stop working correctly.
Windows will close the program and notify you if a solution is available.
