I need the tutorial recorder to do some lessons, but ..I don't know how to use it!
I click on the record button but nothing happens...then i click on generate and is the same.
Would you like to be so nice to explain to me how does it work?
Marco
Tutorial recorder Topic is solved
Re: Tutorial recorder
zanimation wrote: ↑24 Feb 2017, 15:25 I need the tutorial recorder to do some lessons, but ..I don't know how to use it!
Marco
The first button is used to start the recording , the second stops the recording and generates an image sequence on the TVPaint timeline. Then you can export that to a .AVI or .MOV as usual.
If nothing happens when you do that then I'm not sure what the problem is , because that's all there is to it .
Did you update to 11.0.6 ? Before in 11.0.3 (and earlier version 11) the Tutorial Recorder was not working on Mac. Now it works on Mac with version 11.0.6.
*NOTE: Tutorial Recorder now works in TVPaint Standard Edition (32 bits) , but only on non-Retina displays. In the TVPaint Pro 64bits version it works on Retina displays.
So if you have TVPaint Standard (32bits) and are running it on a Mac with Retina display it won't work.
Just in case you would be in a situation that involves a Standard Edition on a Retina Screen, you can also use Quicktime to record videos
- zanimation
Thank You all!
I'm downloading the upgrade now and I hope will work.
But I'm pretty sure it will..
Otherwise I'll use Quicktime to recording as Elodie suggested!
Marco
Marco
