Dear Support Forum,
i have been working on a file without problems. When i try to open that file now, tvp is doing nothing. the file is attached:
TVP is on Version 11.0.6-64 bkits
Im on Windows 7 professional Version 6.1 (Build 7601: Service Pack 1)
Any help would be apreciated.
Until then i'm trying to recreate the file from an earlier version (opens without problem).
Thanks in advance
Johannes
TVP wont open file
Re: TVP wont open file
(My system TVPaint Pro 11.0.6 64bit Mac/OS X 10.10.5 Yosemite)
FWIW
Opening TVPaint in advance and using File => Open/Import ...produced an untitled new project file rather than your file.
With TVPaint closed, right-clicking on the downloaded file and choosing TVPaint ...also produced an untitled new project file rather than your file.
(NOTE: I still have the trial software installed along with my purchased license copy and by default my system opens the trial when I just click on a .tvpp file so in this experiment I chose the purchased license copy.)
FWIW
Hi there,
I can't look at it from home, but we will try monday.
- Eric Scholl
Hi Johannes,
We tried to recover your file, but it seems it is completely empty.
We managed to recover other corrupted files before, but I think it's the first time I see a file with absolutely nothing inside it.
Do you remember if you had a problem when saving it ( a crash, your computer shuting down unexpectedly ) ?
Sadly, I think you'll have to continue using your earlier version of the file.
i dont remember anything special. TVPaint runs not very stable on this system anyways. It just quits from time to time at startup. But i didnt notice anything on quiting/saving. It was no big deal this time. I imported many brushes from the previous version of tvpaint. Can that cause issues? Mostly animated brushes with lots of frames. Is there a good way to transfer all the brushes an d panels from tvpaint versions? I think i may have to reset TVPaint completely nad the reimport of all these brushe swill be a very repetive task...
Best Johannes.
Best Johannes.
I am having similar trouble, two of my files will not open either and I am not sure why?
- Hunner Burgin congo soundtrack animatic.tvpp
- (196 Bytes) Downloaded 451 times
Hi, sorry your attachment is only 196 bytes, there's nothing in the file ! I'll send you a link by PM to upload the fileHobbes_205 wrote: ↑17 Jan 2022, 18:57 I am having similar trouble, two of my files will not open either and I am not sure why?
Hi, sorry the file you uploaded is not better : 439 bytes only.
