Random in Re-Apply
Random in Re-Apply
If I draw something with an animated brush which is set to random, each stroke starts with a different frame. If I, however, re-apply that brush, in each frame it will start with the same frame. I'd like to have re-apply behave more like re-drawing. This would make creating living lines of static objects more easier.
Re: Random in Re-Apply
Markus,
Try this instead. It should work frame by frame or over selected frames... and it should apply to heads only.
EnterKeySubstitute.tvpx
(80 KiB) Downloaded 1104 times
