My "Display" check box for CutBrush operations has stopped working Topic is solved
Normally, if I want to capture drawing on two or more layers, I initiate a CutBrush operation and check the "Display" box. Lately, I can't seem to get this to work - checked or not, only the current layer is captured. I'm using version 11.0.6.
Can someone verify this for me to see if the problem exists in your current TVPaint as well? Thanks!
Re: My "Display" check box for CutBrush operations has stopped working
Works in 11.0.3 (I should update, I know ...)
slowtiger wrote: 12 Jun 2017, 15:58 Works in 11.0.3 (I should update, I know ...)
Thanks... I guess I'll try a fresh install and see if the display check box works there. If it does, then it is probably my config.ini file acting up and I'll try to refresh that.
EDIT: turned out to be a bug in a script that disabled the DISPLAY option for CutBrush Operations even when checked.
