adjusting layer opacity Topic is solved
leszczynska
Post by leszczynska »
Sorry if that was already mentioned somewhere, I can't find that: is it possible to set layer's opacity by typing a number, not sliding the slider?
I need to put opacity on certain values, and I'm finding myself going crazy trying to adjust the slider to exactly that number. It would save me a lot of frustration to be able to just type it in.
Thank you.
Re: adjusting layer opacity
In v10 you could just double click into the value field, a popup appears where you can type in any number.
In v11 this doesn't work any more. I agree, it definitely should!
leszczynska
Thanks! Oh yeah, I forgot to mention I'm using version 11.0.6 32 bits, standard edition.
Let's hope that's something the team could fix for the next update then (•‿•)
NathanOtano
Post by NathanOtano »
Yeah I miss that too
Just a tip : if you use right click on the slider, it moves the slider 1 by 1 (to the right if the cursor is on the right, to the left if the cursor is on the left).
leszczynska
Thanks Elodie, that will be very helpful!
Joost
Post by Joost »
I also miss this feature in TVPaint 11.
Why was it changed? It worked really well in TVPAint 10.
TVP Pro 11.7.1
