Pieces of audio play in TVP 11 but NOT in export!
marijaye
Post by marijaye »
Been a while, everyone, but here I am again with a bizarre sound issue!
Teaching in a Mac lab using TVP 11 Pro (V11), and I have a student whose project has 3 sound effect layers and 2 song layers in her project. All the audio loads and plays just fine during playback in TVP, BUT the songs will not export (only the SFX) in the .mov's. We have switched the audio from 48 to 44.1 in all sorts of configurations, muted and moved the songs up and down the layers to no avail. BUT ALSO, here's what DOES work...I load a random chicken soundtrack...and the songs appear upon export. Take it out, they're gone. I am not kidding. (btw...the songs are NOT on the chicken audio, it was a random audio file).
I am hoping chickens are not the answer. The file is too large to attach, but if anyone has any ideas I'll find a way to send it to you!
Thanks, all!
mj
mari jaye
Windows 11
11th Gen Intel(R) Core(TM) i9-11900 @ 2.50GHz
32 GB Memory
1TB HDD/ 1 TB SSD/ 2 TB HDD
Touch
TVPaint Pro 11.7.3 64-bits
Re: Pieces of audio play in TVP 11 but NOT in export!
What's the file format for each of the sounds?
marijaye
Post by marijaye »
all the sounds are .wav's, and the songs are .wav's as well. 44.1 khz, 16-bit.
but again, they are all loading and playing just fine in tvp...AND they do export when i bring in a random audio track. we also renamed the song files once and brought them in, and they exported...but then on the second export they were silent again.
it sounds illogical, i know, but after over 20 export tests, it is honestly what is happening!
mari jaye
Windows 11
32 GB Memory
Touch
Hell Marijaye, welcome back :)
Could you please make sure your version is up-to-date ? (11.0.6 ?)
Plus, could you also remind us your OS ?
marijaye
Post by marijaye »
Hi Elodie!
Unfortunately, we are in the last day of student production and we'd need to update all 145 TVP licenses to test this out!
I've let the Animation Manager at this school know, and he'll update at a later point.
For now, I will mess around with the song files themselves to see if I can trick TVP into liking them.
Thanks to you both!
mj
mari jaye
Windows 11
32 GB Memory
Touch
Ok well, I am sorry, I cannot help you more if the software is not up to date or without knowing your OS :/
Good luck anyway for these last crazy days ! :D
what is your current version ? (to check, go into : help > about)
marijaye
Post by marijaye »
Hi Fabrice! :)
Elodie, we are using OS Sierra, and apparently we ARE using 11.0.6 already!
Do you want me to send you the file somehow? It's over 700 MB so I can share a Google Drive folder with you?
mari jaye
Windows 11
32 GB Memory
Touch
hello,
yes, you can share with us through google drive.
use tvpaint [ @ ] tvpaint [ . ] fr as email, so both of us will receive the files.
Bug confirmed on my side on Windows.
I'll add-it in our todo-list.
It affects soundtracks that span over several clips, as is the case with this project.
What I did was use the "Split Track to Clips" on one of the soundtracks and all sounds were correctly played when exporting.
//EDIT: I noticed the problem does not appear when exporting to AVI, only in MOV, so chosing not to export to MOV would also be a solution.
marijaye
Post by marijaye »
Great!
Thanks, Thierry and all, for looking into this! I'll let the Animation Manager know we weren't going crazy!! And also that .avi is also a solution.
Best,
mj
mari jaye
Windows 11
32 GB Memory
Touch
