CTG layer, not CGT (it won't go on strikes
CTG layer works fine with any kind of line, as long as it is minmum 75% opaque and 2 pixels large. Even on drawing made on paper :
https://www.tvpaint.com/doc/tvp11/index ... pplication
I might be wrong but I think Krita used Lazybrush technology, which is the same technology used for CTG layers.
The difference is that we bought Daniel Sykora's technology and optimized the code to make it work perfectly in TVPaint interface for animations (including automatic palettes, colour tracking for textures, automatic calculation depending on sources, etc..). The purpose of CTG layer is to fill the whole drawing with all the colours within a single layer. So yes, it may spill out if you use a single colour! The CTG layers' technology will colour areas following the sources' lineart AND squiggles (other colours) applied.
I guess it could be simplified to "add the CGT layer to the paint bucket" feature request.
I guess you could just give actual feedbacks on the use of CTG layer and try to understand it instead of giving non-sense development advice.
At least share an example and tell us what went wrong (there might be a bug after all). What is the point of coming here, say you appreciate a feature from Krita, and finally won't give a chance to the exact same feature in TVPaint ?
Post pictures, show us your lineart, tell us what you want with visual examples. If you cannot take the time to do this, it means you don't really want any improvement in TVPaint.
