Audio problem Topic is solved
- David_Fine
Audio problem
I have three .wav files in a project and I need to turn two of them off, but doing so does not mute them. Even after deleting the .wav files from the project, they still play. When I delete all the .wav files, the waveform is still displayed and they all still play. What is going on?
David Fine
Snowden Fine Animation Inc.
Vancouver, Canada
Vancouver, Canada
Re: Audio problem
You have two possibilities where to put the soundfiles. They can be project-sounds or clip-sounds. You could check if your sounds are accidentaly imported to both situations. If yes, you have to delete them in the clip(s) AND in the project.
TVPaint 10.5.7 - Win10/64
TVPaint 11.0.8 - Win10/64
- David_Fine
Re: Audio problem
Ha, you solved it. For some unknown reason the audio was in the project as well. I only ever load audio in the timeline so I don't know how this happened. Didn't even know it could. So I went to the project and deleted the master audio there and that did it. Thank you!!
David Fine
Vancouver, Canada
Vancouver, Canada
